Glow plug replacement torque
Old Oct 20, 2008 | 03:42 PM
gflatt's Avatar
1999 e300td
Question Glow plug replacement torque
Just finished replacing all 6 on my 99 E300td, cleaned out the chambers with a gun brush and was amazed at the carbon that came out with the siphon gun. Blew all back through the intakes, shop-vac'd everything and we're back in business.. BTW: the 3/8 impact gun at low power was THE answer!
BUT.. any recommendations on the torque specs? Bottom-out and 1/4 turn or 12-15 ft/lb like a spark plug in an alu. head?
You guys have been a tremendous aid so far, we'll try to post some pics later of the job. Not bad for the average mechanicaly inclined person with a few common tools. Full write up to come if there is interest.
Old Oct 20, 2008 | 07:16 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
I cannot help you on this but would love to see some photos of the carbon that came out of the chambers. Is this method of cleaning recommended by MB? Please post lots of photos.
Old Oct 20, 2008 | 08:34 PM
Untertürkheim's Avatar
I have cleaned a lot of carbon out when replacing glow plugs, although from what I remember there is a special reaming tool that will get all the carbon out. I hope the gun brush will too, although the reaming tool seems to be a bit better suited for removing the carbon.
Old Oct 21, 2008 | 08:28 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Torque to 20Nm
Old Oct 21, 2008 | 10:41 PM
TMAllison's Avatar
09' E320
You might want to use some antiseize on the threads and shaft of the GP too. Most DIYer's use it when they replace them. I dont thnk MB has ever come out and recommended it.
Beru makes a special grease they recommend for their GP's as well.
Old Oct 22, 2008 | 09:29 AM
gflatt's Avatar
1999 e300td
Cool glow plug torque
Thank you for the info. upon default I torqued to 150 in.lb.. so feel OK about that. Anti-seized the threads, reset the OBD2, and no check engine light,
I still have a bit of a one cylindered miss at cold start,?? Was their a opportunity when all the GP's were out to do a compression check? I suspect so,
and do any of you know the compression, my gauge tops out at 300#.Will probably be back in this weekend to meter the GP's again, and see if not reaming has shorted one out.
Old Oct 23, 2008 | 10:53 PM
EdzBenz's Avatar
W210 W140
Did you use the impact wrench on low to remove the GP's?
Old Oct 29, 2008 | 04:11 PM
gflatt's Avatar
1999 e300td
Inpact gun?? YES ("3/8")
Started out very cautious but soon felt comfortable at full flow, (125#) at regulator. Using my left hand on a 8" extension to modify the initial shock. As movement was observed, reversing and reversing oiling[(KANO-KROIL) or PB blaster or similar lubricant]. and yes every one came out,confidence builder with every one. 3/4 length socket works extremely well, It rides the glow plug out, were a common deep well socket allows the glow plug to ride out, with in the socket and damaging the threads on the GP on the way.
