84 300SD rocking engine when warm
Old Jun 14, 2010 | 08:33 AM
jhutton's Avatar
84 300SD
I have an 84 300SD, recently i have replaced the following, motor mounts, motor shocks, rack idle bolt
when the engine is cold and you start the car, the engine does not rock at all
but after 20-30 minutes of driving and you come to a stop, the engine shakes the car
the idle seems right its a 750-800
any advice would be great i love this car
Jason
Old Jun 14, 2010 | 09:37 AM
oldsinner111's Avatar
s320
Make sure you use German Hose clamps,at all hose connections.It sounds like air causing this.A hose will not drip fuel,but can let air in.I make a fresh cut in fuel hoses anytime I change filters.
Old Jun 14, 2010 | 11:22 AM
TMAllison's Avatar
09' E320
Did you check your trans mount?
Is the trans going into 2nd at stop lights, or staying in 1st?
Beyond that, look for anything that might be in contact with the engine and the frame or body. I had a MB Tech do motor mounts on an 82 once, when he finished he set the engine down on top of the windsheild washer bottle and called it done. I hopped in when I picked it up, fired it up, and immediately turned it off. So much vibration I could hardly find the key to shut it down.
Old Jun 14, 2010 | 08:18 PM
jhutton's Avatar
84 300SD
my brother dose all the work he is a diesel mecahnic with 10+ years experience,
as for the air leaks he did check the injectors, is there another place to check?
the engine shacking is in neutral and first once rev are around 1,000 its as smoth as can be
FYI - i will get new filters and cut hoses this weekend
what about the filter in the tank is it worth changing
thanks for all the advice
Old Jun 17, 2010 | 06:45 AM
s320
other leaks
Fuel tank screen O-ring,Rear fuel lines.I always tighten lines so they will not move,and use German clamps.Other clamps cut into rubber lines.The only time you use US clamps is for radiator clamps,the german ones are skinny and can break off the necks.Tank screen clogged can cause bad idle too.
Old Jul 21, 2010 | 09:14 AM
jhutton's Avatar
84 300SD
thank you i will replace filters, tighten the hose and drain the tank next time its close to being empty
nother though could it be valves, i am close to my 15K miles to
adjust the valve clearance
Old Aug 18, 2010 | 08:33 AM
jhutton's Avatar
84 300SD
update, i have replaced all of the filters except the one in the bottom of the
fuel tank, also adjusted valves and they were not off much
still has the same symptoms, my brother thinks it could be the injectors
he actualy thinks its just the number 5 cylinder
what do you guys think?
