Oil change problem
Problem is i went to buy the oil and the guy said i need to find out if my car has a diesel particulate filter or not, because there's a Mobil 1 ESP for the models with the DPF.
Can anyone confirm? or better still, tell me what to look for on the exhaust?
The link provided in the thread has the correct info for N.A., that does not mean it is the correct data for your model in Europe. New technologies are generally released there a few years earlier than our receipt in NA.
I do not have a DPF ( Australia) but I am told it is a canister in the exhaust system with two small take off pipes which measure the differential pressure across the DPF & tell the engine management that the DPF needs regenerating.
You may be able to find this system.
The oil recommended in Australia for both DPF & non DPF W204's 220CDI is
Mobil 1 ESP 5W /30.It is what I use.
