W211016 e270cdi mod
Old Sep 7, 2011 | 06:26 AM
kevtan's Avatar
w11 e270cdi
W211016 e270cdi mod
Hello there. I'm Kevin Tan from tropical Malaysia. Currently owns a 2003 w211016 e270cdi with 722.640 autobox and w211 e220cdi 6 speed manual. I have tried to get the AMG nozzle but apparently they are not available here. Would it be possible for those that had done the nozzle replacement help me by pointing me to a reputable vendor or even injector servicing shop that can help me do the exchange?
So far the 270 with cdi3 om617.??? has been decatted with a straight pipe and removed dpf. The 220 om612.??? of the same year has had the dpf gutted. The only mods done to these are was having the 270 remapped. It was doing 11 sec 0-100kmh but after cleaning the MAF inside the air filter it is now spinning the rear wheels and dispaches the same in 8.9 sec.
Found out that the ecu cuts power if the intake temp exceeds 50degC which is easy as the ambient here is 38degC. Would a bigger FMIC be able to cope or would a water methanol injection system be better?
Am planning to scavange for a 270 turbo to hybrid the 220 and a 320 turbo fitted to 270 hybrid. Is this a good and cheap combination that is also durable?
Thanks for the great information from gaiex and tuikku and the rest. Its been very exciting discovering the possibilities and hidden talents in this MB engine.
Old Sep 9, 2011 | 01:36 AM
kevtan's Avatar
w11 e270cdi
Just had a high speed spirited run of the 220cdi and discovered that the injector seats of the head are scored badly on all 4 cylinders and am leaking on the 2nd cyl. Now need to open up the engine to have a good lookover.
1. The head obviously needs to have a steel insert for the injector seat. Am planning to do a 3 angle valve job and polish the runners of both intake and exhaust.
2. Also thinking of balancing the crankshaft.
Besides these 3 things what else should be done to get a better performing and longer lasting engine?
Old Dec 16, 2011 | 03:42 AM
mercuxio's Avatar
W211
Hi Kev,
I too from Malaysia and drives a 270 with Brabus D4 piggyback. Where did you de-cat the dpf ? Mine's already gutted but according to the forum, the hollow chamber creates turbulence. Wanna fit a straight flow to it instead. Trying to avoid Jaffa as it's always packed.
As for your injector scoring, it's call the black death. I had one injector with that problem. The cause of it was the copper washer not seating the injector properly. Replace with genuine MB ones (they are softer) and the problem will go away. I had to place 2 washers in that injector to cure it.
Where are you located? Perhaps we could have a drink sometime.
-Ben
Old Dec 18, 2011 | 12:25 AM
kevtan's Avatar
w11 e270cdi
I think me met before. Are you the Ben that had ECU replacement? If so we met in Shah Alam.
My 270 also had the gutted cat box but I had it cut out and replaced with a mandrel bent straight pipe. The difference is in the top end where the extra ex gas flow have the smooth flow thru the straight pipe. Give me a call 012 214 68 69 and we can talk.
