2008 e320 blutec diesel large oil leak. Any ideas?
Old Apr 5, 2012 | 04:25 AM
mrbill2084's Avatar
e320
Drove the car on a short trip and noticed a bunch of oil dipping from the car when we got home. Looks like its leaking on the passenger side. oil must have been hitting the tire as the front passenger wheel well is pretty coated. Largest pool of oil at the rear of the passenger wheel well.
But what I thought was odd is that there is a smaller pool by the passenger rear tire.. I can see some oil on the passenger door skirt. Maybe it flowed to the rear tire. It was too dark to really see much(plus underside of the engine looks pretty covered up/hard to see.) Any ideas?
The dealer is about 5 mi from my house, but I think I will have the car towed. I hope it will be covered under the extended warranty we bought.. Does not sound like a cheap fix..
Old Apr 5, 2012 | 02:14 PM
listerone's Avatar
2018 BMW 540d
A tow is the best choice,IMO.Cheap fix? From Mercedes-Benz? If it's under an extended warranty it's hard to imagine it not being covered.
Old Apr 5, 2012 | 05:05 PM
Thirdrem's Avatar
1983 300D-turbo "Bonnie"
I agree, it should be 100% covered by the extended warranty. I cant imagine though what would be leaking so bad on a 4yr old car!
Old Apr 5, 2012 | 05:38 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
There is an PCV hose seal near the inlet to the turbo that is a common issue.
That usually causes most to think it's a rear main seal, leaving drip marks everywhere. It can be a cheap enough fix, though probably not at a dealer.
Not sure of your rear area leak? Never heard of that one. Unless it is from the front and the wind blew it back as you drove, then dripped there when you stopped?
Old Apr 21, 2012 | 05:38 PM
pinebaron's Avatar
07 E320 Bluetec
Check area around Oil Filler Cap but you will need to pull off the cover to check if there is oil around the filler cap.
