Gl350 with auto start, stopping on the highway
I own a 2010 gl with 33k miles. Recently, while driving
On the highway, my car's radio turns off and then 2 seconds later my car stops and the steering wheel goes into park position. Thank goodness no one was behind me.
The dealership changed the battery and ignition... Has anyone else had this kind of problem? And if so how did your dealership deal with this issue
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
I assume you are going to take the car back to the dealer, however before doing so check the battery voltage. If you have at least 11 volts, the battery may not be the issue.
Unable to make rail fuel pressure will shut the car down. My point is that someone must determine whether the issue is electrical or mechanical!!
