Where is my block heater?
Old Oct 22, 2015 | 09:45 PM
marc hanna's Avatar
2023 GLK250, 1987 560SL
Hi All,
Does anyone have a pic of the block heater location for their 3.0L diesel (OM642)?
I have a Canadian car and apparently they came standard with block heaters, just not the power cord. I've looked around and don't see anywhere where it would plug in. I haven't definitively confirmed that I have one, so if anyone has some pics, that would be greatly appreciated.
Old Oct 23, 2015 | 05:38 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Are you 100% sure? According my knowledge there is no block heater available for this model, no factory fitted or aftermarket. An aftermarket Electric coolant heater is installed in coolant water hose, if any. Then you might have webasto heater installed, of course.
Old Oct 23, 2015 | 08:17 AM
marc hanna's Avatar
Yes, I'm certain it's a factory option because I've encountered other people with ML's and GL's that have it.
I finally found a pic with one installed:
By the looks of it, I do have one installed, just without the power cord. I have a black plastic cap installed over the threaded receptacle.
Old Oct 23, 2015 | 08:25 AM
mersum1es's Avatar
Hmm.. is it really directly engine block mounted? Would be interest to know who is actual maker of it... I think your local dealer assembles them in cars as an extra option when cars are imported.
Here you can see Calix version (pipe assembly) for OM642:
http://www.calix.se/-file/C80B3ED6D1...C2D7/RE480.pdf
There is also thermo-top brand available where is inner circulation pump.
Old Oct 23, 2015 | 10:17 AM
marc hanna's Avatar
It's only the bronze part that is the actual heater. It looks very similar to the Zerostart version that is made for the engines. It threads into what seems to be a coolant manifold, so technically, no, it's not a conventional block heater because it's not fitted into a frost plug, but it is based on the same concept - resistance wire element submersed in the coolant.
Here's the Zerostart one:
http://www.amazon.com/Zerostart-310-0105-Engine-Block-Heater/dp/B002UNK98I http://www.amazon.com/Zerostart-310-0105-Engine-Block-Heater/dp/B002UNK98I
Verified that it's for my vehicle/engine from the zerostart website:
http://showmetheparts.com/phillipstemro/
Old Oct 23, 2015 | 10:35 AM
mersum1es's Avatar
Why I am asking this, there is no distributor of block heater for that engine in Finland, only option has been that pipe assembly stuff, and we deffo need heaters here in north... but that circulation pump integrated heater has been working well according experiences shared in forum. OM626 is another tale then, it sounds that any heating attempt is messing senors and starting cause EML
Old Oct 23, 2015 | 11:30 AM
marc hanna's Avatar
Well, I got my phone down in there and took a couple pics:
Made in Canada
Old Oct 23, 2015 | 11:37 AM
marc hanna's Avatar
It May actually be a Zerostart block heater (Parent company Phillips and Temro). Up until 2012 they manufactured block heaters in Winnipeg:
http://www.cbc.ca/news/canada/manito...down-1.1178759
Old Oct 26, 2015 | 01:00 PM
marc hanna's Avatar
I checked my E320 (gas) and it has the same heater installed.
Old Oct 26, 2015 | 01:06 PM
marc hanna's Avatar
Here's a pic with the cap removed. Sorry it's not a great picture, it's hard to reach down in there. Basically uses a standard heater cord.
Old Oct 26, 2015 | 01:46 PM
mersum1es's Avatar
In gasser also? That's a good find, and I am still more positive that they are installed when cars are imported in Canada. They did similar things in Finland too. Nowadays it feels that all models are stripped so far as possible...
Old Oct 26, 2015 | 01:54 PM
marc hanna's Avatar
I wouldn't be surprised if all Canadian cars get them.
Old Oct 26, 2015 | 07:55 PM
GLKpaul's Avatar
2013 GLK250 Bluetec
Interesting i'll have to check mine, where you getting the cord?
Old Oct 26, 2015 | 08:13 PM
marc hanna's Avatar
There seems to be two basic types of cords out there that cover off about 95% of all heaters. Ours is the round style with a threaded nut/ring. I will probably get one from eBay or Amazon.
Old Oct 27, 2015 | 09:48 PM
GLKpaul's Avatar
2013 GLK250 Bluetec
Cool thanks
Old Oct 28, 2015 | 10:28 PM
marc hanna's Avatar
I checked a friend's C240; he's got one too.
Old Nov 6, 2015 | 08:06 AM
marc hanna's Avatar
Here is the one I ended up ordering:
http://www.amazon.ca/gp/product/B006ENEM92?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 http://www.amazon.ca/gp/product/B006ENEM92?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
Old Nov 6, 2015 | 05:59 PM
marc hanna's Avatar
Here it is installed now on my E320:
Here is the cap that must be removed:
Old Nov 6, 2015 | 06:55 PM
marc hanna's Avatar
Infrared heat gun reading 75-degrees Celsius at the heater and 35C at the top of the rad hose after 1 hour.
Appears to be working great.
Old Nov 15, 2015 | 12:42 PM
marc hanna's Avatar
I got my DEFA MiniPlug kit today to do a permanent install in my R320 CDI. It comes with all the required mounting hardware. All I have to do is attach the heater plug to it and a North American 120 male plug.
Old Nov 15, 2015 | 04:21 PM
marc hanna's Avatar
. . . now I got it all installed . . .
Old Nov 16, 2015 | 09:42 AM
fireman1073's Avatar
97 s320
here you go..http://www.afterhoursautoparts.com/z...bSxRoCBnHw_wcB
nice setup marc
Old Nov 16, 2015 | 12:49 PM
marc hanna's Avatar
Thanks.
For anyone who has the heater pre-installed the cord can be found on eBay and Amazon:
Phillips and Temro part# 3600008
There are also variant part numbers with different cord lengths. It also fits many other vehicles and tractors.
Old Nov 16, 2015 | 01:26 PM
marc hanna's Avatar
Kat's/Five Star Manufacturing will also work
Part #'s
28206
28216
28416
28316
Old Jan 22, 2016 | 06:12 PM
marc hanna's Avatar
BTW. Loving the block heater in this -15C weather.
