2014 GLK Fuel Pump
Subscribe
Nov 12, 2015 | 06:56 PM
The fuel pump on my 2014 GLK Blutec was just changed under warranty... Question I forgot to ask the dealership: when I turn off my GLK there is always the sound of a pump running for about 30 secs, is that normal? It is in the rear end of the vehicle so I assumed it had to do with the fuel pump or DEF fluid. The vehicle has always done this so I thought it was normal.
Reply 0
Nov 17, 2015 | 01:27 PM
pump noise after engine shut off?
I have sent the attached audio file to the dealership...
What do you think...
Reply 0
Nov 17, 2015 | 02:52 PM
Stupid question, but are you sure it's coming from the back? Every recent supercharged and turbocharged MB I've had runs the intercooler pump for 30 seconds after the engine is shut down. It makes a high pitched whine sound. But this pump would definately be under the hood.
Reply 0
Nov 17, 2015 | 03:43 PM
Definitely in the back end... I posted a recording above: I was under the back emd when I recorded the sound...
Reply 0
Nov 19, 2015 | 08:32 AM
Pump noise after shutdown is normal...
Here is the note from the dealership...
"As discussed on the phone, the noise that you are hearing after shutting the car off is normal. Your car has a saddle tank so when the car starts it only draws from one side of the tank. The pump noise you are hearing is and internal pump that sends the fuel from one side of the tank to the other."
I must say I am surprised he didn't already know this...
Reply 0
Subscribe
Currently Active Users (1)
