Power steering 270cdi
Old Jan 9, 2017 | 10:46 PM
Steviemboy's Avatar
2000 ML 270cdi
can't seem to find what the power steering oil capacity is...I have drained and clean reservoir, turned wheel lock to lock and rolled pump to remove all oil ...does a 1 litre MB bottle of p/s oil enough ?
Cheers
Old Jan 9, 2017 | 11:03 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Capacity for a C Class is .8 L
POWER STEERING.
Capacity 0,8 liter
Use:Normal
Products:
PENTOSIN CHF 11S
TITAN ZH 4300 B
Make sure you bleed out all the air before travelling on the road.
The best way for a C Class is to raise the front of the vehicle & turn lock to lock gently up to say 10 times.
Old Jan 18, 2017 | 01:46 AM
Steviemboy's Avatar
2000 ML 270cdi
Thanks purchased a litre of germany P/S oil for MB at $NZ17.50 ...opposed to MB dealers oil $NZ51.20...
Yes 800mls was the quanitity needed to fill after flushing all lines ...last 200mls put in once ML started and pumped pressured oil into radiator ...
All good
Thanks for advice
