What maintenance should be done on 3.0 V6 CDI
2008 ML320 CDI
Just picked up an 08 ML320 CDI with 109K miles and figure I should some preventative maintenance soon as the dealership sends over the maintenance history. What things should I consider replacing now?
Oil & filter Drain not suck
Fuel Filter
Clean sensors Air Flow?
Glow Plugs?
Clean EGR?
Clean Intake does it have the swirl valves?
Oil Additive (not sure if stiction is really a thing and if its a thing on this engine)
Injector cleaner
was also thinking about a tune to remove the DPF and EGR so I don't have any issues with them.
Fuel Filter
Glow Plugs?
Clean EGR?
Injector cleaner
Received 1,730 Likes
1922 Ford Model T / no OBD
Just follow the car FSS.
I never used any additives on MB and had couple of them reaching 300k miles.
Change the oil and filter and live long and prosper. However watch out for the idiot that suggest taking fan blades off the fan to have the engine to run cooler!!
PS: Don't screw with the emissions system via a so called tune. If you are clever enough, you can eliminate the DPF via a software patch(google DPF removal)
2008 ML320 CDI
