R320 CDI W251 DIESEL PROBLEM NOT STARTING
hi fellow MB friends.. I am new in here and need to pick your brain to solve this issue i am having,,,
I have a W251 2006 R320 cdi and having an issue for not starting, it cranks then it will start for a 1-2 secs then it will dies but then you can always start again and again but only 1-2 second enigine runs...
I have sent the Hi-pump to get it checked plus replaced the lo-fuel pump (in the tank) i have replaced fuel filter and the Glow Plugs even the module because it was showing that it was faulty but then still the same issue...
i am guessing it has a low pressure of fuel, the reason i said that... I loosen up the high pipe coming from the hi-pump and the fuel there was dribbling, i have checked the fuel pressure between fuel tank to fuel filter and showing 55-60psi and the i checked the between fuel filter to hi-pump and showing 55-60psi also..
i ran out of ideas please help, if you have same issues and sort out the problem... thank you!
Received 1,749 Likes
1922 Ford Model T / no OBD
Right now even $20 Bluetooth adapter for my android shows me rail pressure.
Get one and come back with data.
That is something that can be hard to confirm with manufacturer, but if I remember it correctly, at idle my 3l BT makes 5000 psi and goes close to 20000 at higher speeds.
Will recheck tomorrow.
i gathered when its on idle @700 rpm i got 321(bar) = 4655psi
when i was revving it on @1600 rpm i got 653(bar) = 9470psi
I recheck it today and it is how I remember it.
Oscillating around 5000 psi at idle and hitting 18k under the load.
The high pressure jumps up and down in city driving very fast, but what I noticed it is related to load, not to rpm.
Meaning when I push the pedal, it will jump to 18k below 2000 rpm.
So my conclusion is that your pump giving max 9k is not performing.
you meant the hi-pump or the low-pump...?
just to let you know i sent out the hi-pump to get it checked but they said its all good but then we assumed the low-pump could be the issue because i thought the 55-60 psi fuel pressure wasnt enough but then we replaced it but still same pressure out put 55-60 psi so 100% it wasnt the low-pump....
I think you need to get a thorough diagnostic done before spending money on any more high ticket items.
It is not a normal thing for a diesel to stall out in the way you describe. It could be related to exhaust restriction, intake restriction, fuel restriction, faulty electrical, faulty injectors, faulty rail pressure sensors . . .
as I mentioned before we checked the fuel pressure and got the hi-pump serviced plus checked airfilter and turbo charger plus checked the exhaust system... No Faulty codes showing on our scanner...
RAIL PRESSURE (Bar) 4
CURRENT INJECTED QUANTITY (mm^ 3/Hub) 23.9
PRESSURE CONTROL VALVE (%) 11.0
QUANTITY CONTROL VALVE (5) 0.0
when ignition ON:
RAIL PRESSURE (Bar) 13
CURRENT INJECTED QUANTITY (mm^ 3/Hub) 23.8
PRESSURE CONTROL VALVE (%) 29.7
QUANTITY CONTROL VALVE (5) 40.6
when cranking position:
RAIL PRESSURE (Bar) 193
PRESSURE CONTROL VALVE (%) 36.2
QUANTITY CONTROL VALVE (5) 57.6
when its on IDLE: 700rpm
RAIL PRESSURE (Bar) 297 - 321
CURRENT INJECTED QUANTITY (mm^ 3/Hub) 15.6 - 16.1
PRESSURE CONTROL VALVE (%) 15.9 - 16.2
QUANTITY CONTROL VALVE (5) 27.4 - 27.8
revving 1607rpm:
RAIL PRESSURE (Bar) 653
CURRENT INJECTED QUANTITY (mm^ 3/Hub) 23.5
PRESSURE CONTROL VALVE (%) 23.4
QUANTITY CONTROL VALVE (5) 33.0
