Oil additive tested in W164
I was thinking in some additives like Liqui moly Ceratec. I'm open to listen opinions about,
Best regards
How will you judge if the engine is wearing less?
Besides, how will you know if it's doing anything? Seat-of-the pants feeling is only anecdotal. Is it the placebo effect your feeling? How will you know if it's actually reducing engine wear and not messing up the oil chemistry? Maybe that's why MB doesn't recommend anything.
Unfortunately I don't think your experiment will prove anything of scientific value. But it may make you feel better at the expense of your wallet.
Its hard to prove if the engine will reduce the wear because I´m not an expert mechanic, I only can tell you what´s my experience after 250 kms using the car in a very extreme wheather ( - 5 ºC during night +25 ºC day) that`s why iI decided to test it, to see if there´s some possitive effect, like reduce the noise and make the engine work softer.
Best regards.
I guess each thing you do to improve your car gives you a placebo effect...that´s the idea to use the best oil or the best parts you can afford.
And what you say about MB doesn´t recommend anything...they even not reccomend to change the transmission ATF because the transmission is sealed for life... very convenient for them to make the customer must buy a new transmission at 100K miles. therefore what MB advice doesn´t need to be a rule.
Regarding If I´m trying to prove something scientific with this additive, I can tell you thats not my goal, I´m only trying to improve the oil performance, taking the experience of many people in germany whom use this additive after each oil change, besides I don´t think, that this additive may reduce the oil quality.
Best regards.
Here's the link: https://540ratblog.wordpress.com/
