Glow Plug Replacement - 2006 cdi
Here is the history of my glow plug replacement(s):
Jan 2011 at 58,000. Changed all six
Oct 2012 at 80,000. Changed #4
June 2016 at 134,000. Changed glow plug controller
NOW at 155,000. #3 is bad.
I read somewhere that it may be best to change all six since I have close to 100k on them. I also have my wife and I turn the key to "on" and wait until the GP light goes out, then we start the car. This is just something that I think helps the glow plugs last longer. And yes, I know to use Beru 5 volt glow plugs. I will start soaking them with oil while they are being ordered.
Thank you,
Mike T.
Driving diesels in CA I replaced GP only once, so I consider them 1/2 million miles item. Obviously in cold states where you have to preheat for long time the story is going to be different.
I no longer own cdi engine, but from my recollection it does have easy access to GP, so I would replace only the bad one.
Some engine require puling manifold for GP access and in such situation, I would replace them all.
Thanks again,
mike T.
