Swirl motor resistor mod
Old Jul 12, 2018 | 10:03 PM
dieselolds's Avatar
2008 E320 bluetec
Hi to everyone.I’ve only posted a few times since I joined here a couple years ago but this past week my 08 E320 Bluetec showed a P2015 and after doing a search here i was pretty amazed that a 25 cent 4.7K ohm resistor could fix that problem so I went ahead and did the mod a few days ago.It turned out perfectly.I also removed the top plastic engine cover so the engine could cool a little better.I just wanted to say thank you to everyone here for their helpful responses.I do appreciate it.
Old Jul 12, 2018 | 11:43 PM
Micah / AF1 Rac's Avatar
W211 e320 CDI
Make sure you have a high enough wattage resitistor as too low may checksum fine but burn up quickly with load applied to it. Lesson learned on V12 BMW 750il e38
Old Jul 15, 2018 | 08:01 PM
dieselolds's Avatar
2008 E320 bluetec
Thanks for the heads up on that.The resistor I’m using is 1/4 watt.Is that okay to use?
Old Jul 15, 2018 | 08:38 PM
W211 e320 CDI
I ended up using a pair of 5w but it’s all about the draw of the motor and Ohms law
Old Jul 15, 2018 | 09:16 PM
dieselolds's Avatar
2008 E320 bluetec
I’ll keep an eye on it anyway.Thanks for the reply on that.
Old Jul 16, 2018 | 11:36 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
50 milliwatts is well within the realm of a 1/4 watt rated resistor. What am I missing that you needed a pair of 5W resistors? Parallel or serial? What resistance did you use? You know ohm's law so you must also know what two resistors in parallel will do.
Old Jul 16, 2018 | 12:28 PM
W211 e320 CDI
Yes, for crankcase vacuum/air injection blower motor on e38 750il V12 BMW.
