fuel rail pressure question OM642 CD4
Old Mar 31, 2023 | 03:31 AM
  #51
virgisr's Avatar
Mercedes R320L CDI 4MATIC 2007
Originally Posted by Quint22
I am still tempted to do that. Any reason not to? Ya can literally buy a foot of fuel line at auto parts store and the 4 clamps and be good to go.
Its one of the ways. We are aware of this way, not a secret to us
Clamps which can be unscrewed can get undone in time cause of vibrations. To me not too reliable. Had that not once.
Old Mar 31, 2023 | 10:11 PM
  #52
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I can think of two reasons for those spring clamps: ease and speed of (factory) assembly and uniform clamping pressure. Quality fuel injection clamps won't loosen up from vibration. Just don't use worm clamps; they dig into the hose too much.
Old Apr 1, 2023 | 12:28 AM
  #53
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Never in all my years have I scene the hose clamps loosen up due to vibration, guess it could happen but would have been very poorly installed or very low quality IMHO.
They can if over tightened. I like the tbolt style myself but not really for small hose applications. The spring tension ones I like also, regular pliers will work just fine on them which makes it easy to pop off and on.
Old Apr 1, 2023 | 09:04 AM
  #54
John CC's Avatar
You want one like this. It clamps ll the way around the hose and the edges are rolled slightly so they don't dig in to the hose.
Old Apr 25, 2023 | 05:24 PM
  #55
B34chBum's Avatar
R320, Astro, JSW, ST4
Thanks for your posts/follow up, stars-gatherer - Mine started behaving badly again, and I'll check the hoses leaving and returning to the engine area.
I'd replaced the ones near the filter, and the one for the injector returns.
The diagram helps to see how those 2 hoses would have plenty of movement with engine rocking.
I know well how tight the clearances are in the R-Class engine bay!
Another good example is changing the upstream O2 sensor - helps to have a 3' extension!
(You still have to remove righthand air cleaner)
Old Apr 26, 2023 | 04:22 PM
  #56
stars_gatherer's Avatar
R 320 CDI D6 BRABUS
Hi,
As of now I have changed all of the hoses that could have been responsible for the longer cranking during start up, yet the problem is still there. I think that in the next step I'll be replacing the camshafts position sensor as I red that the longer cranking could be caused by a faulty one, especially if it is intermittent. Then if also that doesn't work I'll follow the glow plugs path.
Regards,
Francis
Old Apr 27, 2023 | 10:34 AM
  #57
kajtek1's Avatar
1922 Ford Model T / no OBD
Check codes.
Good scanner will also have live data, who will troubleshoot the issue before opening the hood.
Old Jul 3, 2024 | 03:50 AM
  #58
blfmtriv's Avatar
2014 SPRINTER V6 LWB
HI ALL, this thread has been a very interesting read, i also are having starting issues,
i have a 2014 sprinter 4X4 OM642 ENGINE LWB hi roof
what i,ve found is this is, I live up in the tropics of Australia, where it is 30 deg c all day 365 days of the year
hard cranking started about 2 weeks ago while i was remote in the outback
since then i have changed fuel filter
DPF burn
added to 4 tanks of fuel system cleaner
plugged in my ICARSOFT MB11
results are pretty consistant at the moment, I carried out the same test 10 times under different temprature conditions
my electric tank pump, pumps to fuel rail pressure of 12.13 bar +\- .2
the pressure control valve is between 8.58 - 11.01 % open
the Quantity control valve is also open 33% this should be closed for cranking
the quantity control valve closes to 0% after 30 seconds KOEO
i crank the engine and it starts normally at 2 seconds
if i try and crank before the 30 second switch over it is a prolonged crank and rough start
my injection volumes are between 9 and 10.3 mm3
engine starts and fuel rail pressure consistant at 257 bar every time
i,m yet to find what circuit is the Quantity control valve powered by, but i also have found a very small whisper leak in the return line on the injector of 1 or 3 depending how you look at it,
i,m finding a very small spray of oily substance on the turbo pipe,
will try and remove the return line and inspect o ring
