OM642 - Engine bad knocikng
Old Jul 18, 2019 | 06:06 AM
Gonczy Andras's Avatar
2007/W221/S320cdi
Dear Members,
I am knew here, so please do apologize me if this topic came up already.
I have a Mercedes W221 S320 cdi from year 2006, and I have a big problem.
After driving 100 km on motorway, I stopped the car and it was very difficult to start again the engine and started to knocking. The first step was to replace 6 injectors (they were leaking), but it did not solved the problem.
Here is a video about the sound of the engine
Even before the injectors have been replaced, we went a few kilometers with the car, at the beginning the knocking was less loud, but then when the engine warmed up it became worse and the engine stopped, and didn't start again. After 1 hour of waiting it started again. During the idle the car is shaking and it lost power. Sometimes it smokes heavily grayish diesel smoke. Do you have any tips?
Thanks in advance,
Andrew
Old Jul 18, 2019 | 10:02 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Mileage? Blowby?
Old Jul 18, 2019 | 10:59 AM
2007/W221/S320cdi
Originally Posted by kajtek1
Mileage? Blowby?
334000 kilometers, what do you mean under blowby?
Old Jul 18, 2019 | 01:03 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
When you had oil changed last time? Check condition of engine oil.
Old Jul 19, 2019 | 04:59 AM
2007/W221/S320cdi
The mechanic told, that the oil seems to be good (within 4000 km has been replaced), however Update: I was told that there is one fault code: Cylinder 3 - misfire detected in the Diag
Old Jul 19, 2019 | 10:27 AM
artim808's Avatar
Try to do injector leak test and report back
Old Jul 19, 2019 | 04:38 PM
Towmater's Avatar
Ml350 bluetec
Who did the injectors?
Did they replace the bolts too?
Were the injectors new that were put in?
Has the vehicle been modified or tuned?
Old Jul 19, 2019 | 05:02 PM
kajtek1's Avatar
Blowby test can easy tell you if your rings/pistons are still holding.
With engine off, remove oil fill cap and put napkin over the hole. Start the engine and see if the napkin stays at idle. If it blows- repeat with light cardboard.
Single cylinder misfire should not kill the engine, so I think you might have more than mechanic tells you.
MB-oriented scanner will let you do smoothness test, what compares compression between cylinders.
Make sure you don't have other problems before you start putting money on new injector.
Old Jul 20, 2019 | 04:01 AM
exhaustgases's Avatar
LS400
Need more that a few seconds of recording, maybe 2 or so minutes.
