GL 350 Blue Tech LIMP MODE
Old Aug 14, 2019 | 11:03 AM
BHAN GARG's Avatar
GL 350 BLUE TECH
Hello Friends,
I have GL 350 Blue Tech 2011. 138000 KM. went to limp mode 2 days ago. Here are codes : 11D700, 108800, P16E100, P16CC00, P16DA00. One code is for DPF, one for Camshaft hall sensor, what are others for ? Please help.
Thanks.
Old Aug 14, 2019 | 11:34 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
You will need better scanner for this car.
iCarsoft MBII seems to be the best deal at the time. Also check with ScanGauge if they develop X-gauge for your engine to monitor sot level and DPF regeneration.
Old Aug 15, 2019 | 12:00 AM
Towmater's Avatar
Ml350 bluetec
Well, replacing the cam shaft sensor is easy and cheap. Maybe start with that first?
Then check to see if you have any blown fuses.
Then clear the codes and see what comes up again.
Old Aug 15, 2019 | 12:05 AM
Towmater's Avatar
Ml350 bluetec
16CC00 is add blue level low, so the add blue sensor is bad if the tank is full ??
16DA00 is pressure control deviation too high
