2011 ML-350 - Oil Consumption
That is still within specifications, although usually MB engines burn less.
Lack of oil stains under the car doesn't mean much. Did you check belly covers?
Other issue might be your turbo seal leaking oil into intake, what will eventually burn it.
Still 3l for 10,000 miles is not much, so I don't think you want to rebuild engine becouse of that?
Turned out MB does allow for hefty oil consumptions (I remember like 1l for every 1000 miles, or something in this range), so even he was pouring lot of oil in it, his complain was not accepted.
Took couple of years to discover that his valve cover was leaking unnoticed and oil was just evaporating/burning without outside trace.
So good luck with your case.
