OM629 Reliability
I've read about the problems the V6 Bluetecs have been having with the oil turning to sludge, leading to seizure, but I presume the OM629 is pre-Bluetec and pre-DPF, so that particular problem shouldn't apply.
Does anybody have long-term experience of running an ML420 and can comment on engine reliability?
The OM629 does have a particular Achilles heel, however; if it's used for short runs, it is very prone to sludging up the inlet tracts, and of course, the DPFs will also suffer. Not normally too much of a problem, but on the W164 the engine bay is so full of engine that anything- and that includes the DPFs, turbos and inlet tracts - other than fairly minor maintenance costs a fortune, because the engine has to come out. In fact, I've just sold mine because of that; I've not been doing many long runs, and I got sick of doing an extra ten miles on most journeys just to be sure...
I hope this helps.
Get a scanner who can monitor DPF regeneration.
Most popular in USA is ScanGauge, who can monitor lot of things and be permanently plug-in, although with about $150 price sticker.
Lately Autel HT200 come on the market and Walmart sells it below $50. A bit harder to use, but than it is having more options and adaptations.
So having scanner you can observe particles build-up and regeneration status. When particles are coming close to 100% - you should plan longer trip (it is 10 miles on my car) to have good regeneration.
If you happen to have regeneration pending on short trip - take additional loop around the neighborhood till it ends.
It is OK once in a while to abort regeneration, who will restart on next drive, but aborting it few times in the row can lead to troubles.
For intake cleaning - Liqui Moly makes good stuff https://www.napaonline.com/en/p/AOCL...put=liqui+moly, although not easy to use. I already have it on the shelf, but my engines don't have any troubles (knock on the wood) so it is waiting its turn.
Enjoy the drive.
