CDI Injector
Old Oct 13, 2019 | 10:30 PM
CBlakeNS's Avatar
2008 C 350
CDI Injector
I have replaced a seal before but had another injector leak and replaced copper seal. It’s still leaking. With that being said are there any rubber seals on the injector. I didn’t recall any but looks like a few places there should be a rubber seal and not just the copper seal.
Old Oct 14, 2019 | 01:02 PM
Towmater's Avatar
Ml350 bluetec
What are you leaking? Fuel? combustion chamber gas?
Old Oct 14, 2019 | 01:20 PM
CBlakeNS's Avatar
2008 C 350
Spraying / bubbling a little diesel and chuffing if that’s the right word. The only seal on the injector is the copper crush washer at the bottom. Is there any o rings around the injector itself?
Old Oct 14, 2019 | 06:56 PM
Towmater's Avatar
Ml350 bluetec
Did you replace the torx bolt that holds the injectors down when you changed the seals?
Old Oct 14, 2019 | 06:58 PM
CBlakeNS's Avatar
2008 C 350
Yeah I replaced copper washer and bolt. I came home and messed with it tonight just tried new bolt and washer and cranked on it. Seems to have done the job. My torque wrench may be off or something.
Old Oct 15, 2019 | 01:21 PM
Towmater's Avatar
Ml350 bluetec
I believe its torque spec plus 1/4 turn.
Old Aug 14, 2021 | 01:47 PM
ot1's Avatar
ot1
2006 E320 CDI
