Glow plugs
Old Jan 23, 2020 | 12:04 PM
  #51
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Small update. I've decided to send my faulty injector for repair. The diesel shop said that looking at the inside of the injector, I may have a bad fuel pump. He suggested that I start with a fuel pump output test i.e. run the engine at 1400RPM for 60 sec and see that the fuel pressure holds steady. He also suggested that I cut open the fuel filter and see what I find. I think that is a great idea to cut open the filter every time you change it. I always look at the oil filter but never thought to peak at the fuel one.
Old Jan 23, 2020 | 05:36 PM
  #52
kajtek1's Avatar
1922 Ford Model T / no OBD
I used to cut all filters and investigate them, but truth is that after whole USA changed gas stations tanks to double walls, what depends on state happen in last 20 years, you no longer will find fuel contamination.
Even if you fill up at farm station and have corrosion in fuel, the filter will clog and the engine will stop running.
But you should guess the reason when choosing shoddy fill up.
