2012 E350 Bluetec serpentine replacement
Belt broke, bought new kit,
But can't figure out how to replace it
Seems I need to take out the fan out, to remove, a fastner kn the middle of the cover?
Been looking, but all guides and videos are for the gas models, nothing for a w212 bluetec
Thanks for any advice!!!
Good idea to replace 2 idler pulleys and even I did not have issue with tensioner, some advise that one too.
The routing usually is in manual.
I did this a couple weeks back at 78,000 miles because I had an oil leak that soaked the belt. The belt was still 'good' (i.e. no cracks) but the pulleys were all coated in dried oil, so I replaced the two idlers, the tensioner and the belt. Once you loop the belt in the correct order, you again will pull the tensioner to allow you to get the belt around it. See photo below for the nut to release the tension.
