Injector protective cap while working on engine?
Old Jun 27, 2020 | 09:20 PM
ChrisDavis's Avatar
2013 E350 Bluetec
What do you guys use to cover / protect the injectors when you have the fuel rail off? I am replacing the oil cooler seals on my 2011 GL 350 Bluetec and I am going to need to let it sit for probably two weeks before I get back to it. Also, I am going to need to do some cleaning around the head once I get the intake off. I need to cover these open injectors. What do you guys use?
Old Jun 29, 2020 | 02:01 PM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
I bought a set of rubber plugs assortment on ebay and they work pretty well. I can't find the original item I bought, but something like this should work well.
https://www.ebay.com/itm/Auto-Car-Pa...YAAOSwAfVdr8FR
You might also use something like a food wrap as long as it's clear of diesel fuel.
As a matter of fact I did the work in my garage and I didn't cover the injectors. I made sure the area was perfectly clean and there's no possibilities of debris falling in the engine compartment, and I made sure to thoroughly clean all parts upon removal/installation. The engine was put back and now it's been about 1000 miles so far so good. The biggest challenge is that you don't want to use air gun to blow the area if they are not covered.
Old Jun 29, 2020 | 06:13 PM
ChrisDavis's Avatar
2013 E350 Bluetec
Geniushanbiao, Thanks, for the reply. Good info.
