New Timing chain, now wont start on '81 240D
Old Sep 3, 2020 | 01:20 PM
hugho's Avatar
1982 240 D,1985 300D
I have a toughie, folks. My project car is a 1981 240 D in which previous owner replaced the timing chain and then it wouldn't start. Only 100K miles. He said probably bad glow plugs. NOT! So far I have checked cam timing, adjusted valves(WAY OUT!) , bled the system(lots of air bubbles top of filter, and cracked the injector lines. NO fuel coming to injector lines! He also had removed the vacuum pump(WHY?) which I replaced. The vacuum pump is driven by the timing chain and I assume is keyed to the injection pump. I can see the vacuum pump turning when I manually rotate the engine. Is it possible the injection pump shaft is not turning ? IE., could he have disconnected it somehow? Is there any way to tell if the injection pump is rotating short of removing it entirely? Note I have done the timing chain R&R twice on 123 cars and everything went smoothly so I don't see how he screwed this job up. IDEAS!??
Old Sep 3, 2020 | 03:22 PM
dhurley's Avatar
GL320
make sure the pump isnt 180 degrees out of time.
Old Sep 3, 2020 | 06:45 PM
hugho's Avatar
The thought occurred to me but supposedly the pump wasn't removed and wouldn't it still put out fuel thru the lines even if the timing was off? I tried starting it while hitting the priming pump but to fuel output.The car sat for a few yrs also so I soaked the pump and filter with diesel purge. I guess I may have to tackle pump timing???
Old Sep 4, 2020 | 04:31 PM
hugho's Avatar
Tackled pump timing today. discovered the pump was adjusted to 2 degBTDC!! No wonder it wont run. I was able to rotate the pump (advance it) by moving toward the engine but I only netted 4 deg so now it is setr to 6 deg BTDC. I see in the manual that a sliding collar sleve has notched teeth. Which way to I turn the collar to make up this18-22 deg difference? I can't find out how many degrees is each tooth or which way to rottate the pump shaft if that is the way to do it.
Old Sep 6, 2020 | 12:16 AM
dhurley's Avatar
GL320
Its very simple to remove the pump and line it up correctly instead of guessing.
