CEL- P1BAD
CEL- P1BAD
Hello and how are you. I have been doing some maintenance on my sedan. Had the oil filter housing leaking, failed drivers side engine mount. I replaced the oil filter housing ,had a leak. while doing that I also replaced the serpentine belt, idler pulleys,and belt tensioner. No issue.
Engine mounts- I replaced the engine mounts next. drivers side done in about an hour. (had to jack the car up on ramps to get under it.) Passenger side- I could not get the mount out, ended up unbolting the v band clamp on turbo and separating exhaust pipe at what appears to be a ball shaped connection under the car so I could wiggle the old mount out and install the new mount. After driving a short while CEL came on and now getting error code P1BAD What is this code? Fix? Any help would be appreciated. Thanks, E350cruiser
2011 E350 W212 Bluetec Sedan
