Help MB Weirdness (Airmatic, ABS, and shutdown issues.
I had one little problem and it seems to have spawned a few others.
(Cross posted from X164 form for hopefully a better response)
Battery charged and no difference.
A cup of fuel pulled off the filter tap (in case it is water) and exact same results.
Water sensor disconnected and exact same results.
Scan with Bosch OBD reader shows no errors and no communications failures.
Transmission seems to shift through all available positions (P, R, N, D)
No apparent CAN errors (Knows when do is open or closed, remote key and windows work, etc.)
Dash looks normal.
I replaced the AIr-Matic pump, but when I went to start the car it gave me a "ABS/EPS Inop" error.
The car will run for about 5 seconds (about 10 beeps) and shut off (like it was shut down normally).
Restarting the car gave me the same results (tried about 10 times.)
The car did not rise, but I think that might have been because there was not enough time.
I read the codes and had 2
6001-00 ABS Supply Voltage too low Stored and MIL on.
5995-00 ABS Temperature Service brakes.
I cleared the codes and they did not come back, but still have the same symptoms.
Care runs like normal but only for about 3-5 seconds. (Exact same length every time)
Car shows ABS/ESP Inoperative.
No new codes, these codes did not come back.
I put the car on a charger just in case it is just a weird low battery thing.
Will be trying again tomorrow.
Could the car sitting low trip an ABS/ESP error?
Could the ABS/ESP (or sitting low) be a condition where that car shuts itself off since it is not safe to drive?
Dash looks normal.
