ML250 Consuming Antifreeze - where to start?
Old May 13, 2023 | 12:08 PM
ekm's Avatar
ekm
2015 ML250, 06 E320 CDI, 2008 GL320 (sold)
My ML250 w 75K is consuming antifreeze. Low level warning goes on, top it off and its low again after 500 miles or so. Its not leaking anywhere that I can see. Thanks....
Assuming head gasket but thought I would ask. Need to find an indie in my area....Doylestown PA, 30 miles north of Philly.
Old May 14, 2023 | 01:20 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
water pump
Old May 14, 2023 | 03:16 PM
ekm's Avatar
ekm
Originally Posted by kajtek1
water pump
will there be antifreeze dripping from pump?
Old May 14, 2023 | 03:44 PM
chassis's Avatar
2017 GLE350 4MATIC
Yes.
Coolant consumption can either be internal or external.
Extrernal can be confirmed or denied by careful underhood inspection with a bright LED light. Check engine block sides and front for signs of coolant leaks and drips. Do you have drips under the car? Check radiator for cracks and leaking hoses and fittings.
Internal can be confirmed by rough idle, misfire with or without CEL, steam from tailpipe, sweet smell from tailpipe, “washed” top of piston or spark plug, or low compression.
Old May 14, 2023 | 09:29 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
And chocolate milk oil....
Old May 15, 2023 | 12:14 AM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Originally Posted by chassis
Yes.
Its a diesel, no spark plug. Its a diesel with DPF and SCR, you arent going to get much if any at all tale tale signs from the exhaust.
OP, check your engine bay when its hot after long run, stop pop hood and take look around with flashlight. If its external it may only display then. Otherwise check you fluids and have your oil tested. Could be egr cooler as well.
Old May 15, 2023 | 12:26 AM
kajtek1's Avatar
Water pumps have small drain hole at the bottom, who is not visible from the outside.
Small leak will run down the hole and vaporize before reaching engine bottom. Only when the leak become bigger, you will notice coolant dripping.
Get a mirror, or snake camera and look at the bottom of the pump for caked coolant residues.
Old May 15, 2023 | 09:34 PM
2013 ML350 Bluetec
Might also check your transmission fluid. Is there not an ATF cooler built into the radiator? I could be wrong on this model.
Old May 16, 2023 | 08:03 AM
ekm's Avatar
ekm
no rough idle and no antifreeze smell from exhaust....yet. Don't have access to car until late next week and will dive in. I have not checked oil to see if any water instrusion.
Old May 16, 2023 | 10:20 PM
Quint22's Avatar
Veteran: Navy
Remember your exhaust does a really good job of removing things, one of those is smell of stuff that has burned up in the engine and the exhaust. It will not be a good indicator of any type of leak that results in a noticable exhaust change more than likely. You could have a head gasket leak or valve seal leak and never know it if the exhaust is intact and functioning properly.
Old May 17, 2023 | 09:53 AM
ekm's Avatar
ekm
How common is a head gasket leak on ML250 without a causing event? I had a GL350 (2008) that had a leak develop in the cooler that was located in the V of the block. That was an expensive repair and very common from what I understand on the alum block 320 diesel. Hoping this motor does not have that cooler issue and we are looking for a water pump leak. Makes the most sense (if I'm lucky).
Old May 17, 2023 | 11:53 AM
kajtek1's Avatar
On OM654 the oil cooler seals cost $7, when whole new cooler about $170. It is labor to get there what makes job expensive if you don't DIY.
OM651 has oil cooler easy accessible. My 2 cars with this engine, both having over 100k miles don't leak. (knock on the wood)
Old May 17, 2023 | 09:35 PM
Quint22's Avatar
Veteran: Navy
No idea of how common it is, dont think very common. Have not read a bunch about it on the forums here or else where and usually people with problems post the most.
I will say that most in my experience head gasket issues is either replacing the heads on diesels (things can go wrong from time to time), for some reason the engine overheats (lost coolant usually), or the MOST common is a bad tune when they delete there diesels. The quickest and easiest way to blow a head gasket imho. My overall experience is not with MB diesels however so .....
Old May 18, 2023 | 12:09 PM
kajtek1's Avatar
I haven't hear bout bad MB head gasket since W124 era. Last one was manufactured in 1995.
Old May 18, 2023 | 08:55 PM
nelbur's Avatar
1997 E300D
I have a '97 NA 606 that has had a coolant leak from the head gasket for many years. I keep it under control with radiator sealant. I understand that coolant leaks from the head gasket are fairly common on my vintage of diesel straight six. I have seen a fair number on the forums.
Old May 30, 2023 | 08:44 AM
ekm's Avatar
ekm
I inspected the water pump and there is no visable leak after driving/heat up. I did look when cold too and no leak. Looking in the overflow tank and it has a foamy appearance on the top after driving. There is no water or antifreeze in the engine oil. So much for an easy fix (water pump).
Old May 30, 2023 | 12:30 PM
kajtek1's Avatar
Can you take a picture of the foam in reservoir?
Usually with HG leak you will have oil film on top of the coolant, but possible that small leak is not going that fair.
I remember test kits available, who will test the coolant for exhaust gases and oil
Old May 30, 2023 | 04:10 PM
ekm's Avatar
ekm
Pics attached...first one is looking into the expansion tank.
Old May 30, 2023 | 04:41 PM
kajtek1's Avatar
Yup... looks like oil.
My guess is your ATF heat exchanger.
Check your ATF.
Old May 30, 2023 | 10:31 PM
Quint22's Avatar
Veteran: Navy
Yeah thats got something mixing with it.
Old May 31, 2023 | 09:26 AM
ekm's Avatar
ekm
Just spoke to my indie shop and there is a TSB on the engine oil cooler. TSB speaks to replacing the heat exchanger and all the associated tubing.
