ID of '05-'06 e320 cdi charge hose?
Old Jul 9, 2023 | 07:53 PM
Rattaan's Avatar
2006 E320 CDI, 2005 Camry
does anyone have an old/ruptured charge hose they could remove the metal end to measure the inner diameter? i've seen parts sold mentioning 67-68mm but have no good confirmation on that...
Old Jul 10, 2023 | 11:05 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Any reputable parts supplier should match the hose to your VIN.
No need to monkey around.
Old Jul 10, 2023 | 07:45 PM
Rattaan's Avatar
i wasn't looking to replace it, rather modify for a more reliable attachment to my aftermarket intercooler. my intent is to fit a tube inside with a t-bolt clamp instead of using what seems to be the typical reducer elbow fitted to the outside of the original metal hose end, that has popped off on more than one occasion. if i knew for certain the hose id behind the metal end, i could start the process with the proper size tube in hand, rather than hunting for one while the car sits incapacitated. obviously i don't want someone else to mutilate a perfectly good charge hose, so i figured i'd ask if anyone could take a measurement from a deceased unit. i wasn't really expecting much in the way of replies, but thought i'd throw the question out there in the off chance...
Old Jul 17, 2023 | 07:33 PM
Rattaan's Avatar
if anyone else wanted to know, about 1" in from the metal ends the stock hoses squeeze down to about 2.25" or 57-58mm ID on both the hot and cold side of the intercooler.
