Block Heater?
Did you answer his question or recommend a pan heater? I may have missed it.
Can anyone reccomend a wattage for a stick on style oil pan heater?
The pan heater will loose close to 50% of the heat for warming up the air below, so heating element inside coolant is the best, especially that German engineers made the fitting directly on engine block.
Warm coolant will be slowly moving up the block.
Efficiency aside, I don't think warming oil pan, or engine block matters much for the engine start.
We are talking warming up 10-20C up, what in engine work is nothing.
Either way, the engine block will be warmer for starting.
I just want to heat my oil without burning it!
Fire trucks are plugged in 24/7 as they need to take off with high speeds when starting and even the trucks have oil change done more often than in normal use, there are no signs of constant heating lowering oil quality.
The manuals I have read for installed block heaters say to plug it in 2 hrs give or take before driving. This is why most people that I know have a timer plug so you set it for 2hrs before you leave for work or whatever. Saves money also since theres no point in running the heater all night.
My 7.3l Powerstroke had it next to the oil filter... mounted in coolant.
Time of heating depends on the heater power. Those 200W heaters are design to be plug overnight.
When you have 700W heater, that's the one you want to run 2 hr before engine cranking.
My Sprinter has diesel hydronic booster heater. It require engine running and temp below 40F to run.
Strange logic to me as I can't use it to preheat the engine, but then it warms it up fast when running. That's how German engineers see it.
heat rises - so you get not only the benefit of warmer oil fo reasier starts, but the heat will rise and start to warm the block, too. Eventually, I did plumb both the block an dpan heater's cord to one line so I could run both of them at the same time - I figured "why not?".For reference, I used a Wolverine oil pan heater - they're more expensive, but they seem to be a better company - not a fly-by-night internet only company. It looks like they're now Phillips & Temro... but their US headquarters is in Minnesota... where I believe it gets quite cold!
I don't think there's any chance of burning the oil - there's way too much oil in the pan for that. And the engine is still subjected to the ambient temps. Maybe if you only had 16 ounces in there... but then you've got other problems! Get the biggest pad you can. It will probably be about 250W, though. But you could call them and ask them those questions to be sure.
I had a simple, outdoor timer that I used and would typically set that for about 3 hours before I would be starting the engine.
https://a.co/d/iylsL96
