w212 250cdi whit blow engine
Received 1,736 Likes
1922 Ford Model T / no OBD
What country is it?
I know MB like to play with the same engine endlessly, so don't expect easy answer.
MB USA offers rebuild engines in price range of $10,000, what IMHO is the best deal.
Few years ago I bought replacement engine for 2007 E320 Bluetec from UK.
Even it was the same engine block, turned out my original engine had water-cooled EGR, when UK version did not have such cooling.
I was able to add cooling Tees to my original EGR and make it working, but possibilities are endless.
Good luck
Good luck
My understanding is that if all 6 numbers (651.nnn) are the same then worst case is you'll have to swap something that's bolted on, like maybe the alternator bracket.
![](https://mbworld.org/forums/images/ranks/veteran_navy.png)
2014 Cummins, 2014 E250 Bluetec
Do you know whats causing it by chance (head gasket, injectors....). Just curious. Also if it is one of these things have you thought about replacing or redoing said issue or is the engine toast?
Since the engine is 15 yo, there is pretty much information about it on the net. Just do some search.
Here is 1 of nice videos
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
moge (10-29-2023)
