Hi guys I'm trying to figure out where this leak is coming from as I can't retain any coolant in the reservoir since my serpentine belt failed. There initially was moisture by the heater hose/overflow hose and I replaced a clamp and that seemed to fix that issue but there's still a constant drip going down the plastic lining by the tire so I assume firewall area as I don't see anything from the top. Any ideas?
Here's a video of the drip
https://imgur.com/a/wNeSSQh Heater hose Heater hose
Your EGR is on the back/driver's side of the engine near the firewall. Check that out. It's cooled by engine coolant. That and the inlet/outlet to the heater core, as well.
Clean everything off REAL well and then monitor closely.
I replaced the heater hose and that solved the problem. Thanks.
