Intermittent, No circuit 50 signal to engine ecu, stall on light throttle
The van will start once in 50 attempts.
The Ezs sends the circuit 50 signal but the dme doesn't receive it ( per xentry )
When the van starts, the dme instantly shows circuit 50 received and starts.
When the van does start, it stalls on very light throttle 1 -1.5k. literally impossible to hold it.
If I rev it to 2k+ it'll hold it all day but it will loose communications to xentry dme.
The engine can bus has correct voltages and resistance, interior can has correct voltages but mega ohms resistance. Unsure if it has terminating resistors or not.
The van has no fault codes
Had replacement ECU and front Sam
Start authorising every time
Just no start signal into dme.
Any thoughts on my next testing point ?
Oscilloscope on engine can bus ?
How to test if start signal is actually getting to dme ?
Issue with Ezs ? Only pretending to send signal ?
Could this also cause ruining issue ?
Any help would be gratefully received
When I removed the abs can bus from this terminal connector, the van worked perfectly.
The can bus cables had a miniscule short, eg read 2 + mega ohms resistance, should be OL infinity
Ran a new cable, all good
Obviously, anything on the engine can bus, could do the same.
Unplug anything not entirely necessary for starting, see what happens
- ECU engine
- TCU tranny
- CGW gateway
- ISM shifter
- tank pump module
You can get exact network topology from Xentry, a Pro scanner or free from WIS diagram.
