Hi all,
Car details:
Symptom
Very specific situation:
No warning lights, no limp mode, all other shifts feel normal.
What’s already been done:
Recent full ATF service at Mercedes workshop:
However:
Behaviour is unchanged after the service.
Questions
Thanks in advance for any input from people who’ve dealt with similar 9G behaviour.
Car details:
- 2018 C 220 d (W205 T-Model)
- OM651 + 9G-Tronic (725.0)
- ~107,000 km, full Mercedes digital history
- ATF + filter were never changed before the recent service
Symptom
- ~80 km/h in 6th gear, Comfort mode
- Stronger throttle → kickdown 6→4 up to ~3500 rpm
- I then fully lift off
- Gearbox upshifts 4→5
- Right after engaging 5th, with no throttle, there is a noticeable jolt and a small RPM blip
- New pan with integrated filter
- ATF to MB 236.17, ~9 L used
- Level set by overflow method with Xentry, at correct ATF temperature
- No leaks, no fault codes in TCU
However:
- No standstill / gear adaptation done in Xentry
- Only a short teat drive was perfrmed
- Workshop says “not completely normal, but not a big problem, just monitor it”
Questions
- Has anyone with W205 C220d / 9G-Tronic had a similar 4→5 jolt after kickdown + full lift-off (with RPM blip, no errors)?
- Did standstill adaptation / gear adaptation in Xentry improve or fix it for you?
- In your experience, does this sound more like:
- normal 9G quirk,
- TCC / torque converter lock-up behaviour, or
- early valve body / mechatronics issue?
- As long as there’s no slip and no codes, is this usually safe to live with, or would you treat it as something that should be addressed sooner rather than later?
John CC
close
- Join DateJun 2021
- LocationNew Hampsha
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive'17 GLS450, '14 GLK250, Grandpa's Roadster
Liked:521 Times in 420 Posts
Quote:
Try it. You don't need Xentry. If you search on-line I'm sure you can find the procedure. Not sure, but this may do it:Originally Posted by Klynfzl
Quote:
https://youtu.be/7QbpTtpbpWg
thanks for the suggestion, i tried it, but nothing changed. Its doing it at comfort mode though, I might as well try and drive it on a different setting and see if there would be any jerking. Originally Posted by John CC
Try it. You don't need Xentry. If you search on-line I'm sure you can find the procedure. Not sure, but this may do it:https://youtu.be/7QbpTtpbpWg
Today Lueg AG dealership in Essen, Germany replied to the case as well:
Quote:
Thank you for your detailed description and the comprehensive information about your Mercedes-Benz C 220 d (W205). Please find our response below:
- The behavior you described is rather unusual and requires an inspection according to official Mercedes-Benz manufacturer specifications.
- There are no specific service bulletins related to this issue; however, a thorough diagnostic check is necessary.
- The inspection will follow Mercedes-Benz guidelines, including a test drive with Xentry, reading fault codes, and checking for available software updates.
- The transmission oil should be changed no later than 80,000 km. Your digital service book shows no record of such a change, so we strongly recommend performing it now.
- A transmission oil change or flush is always beneficial for the longevity of the transmission, especially under severe operating conditions such as towing.
- Perform diagnostics including software check and adaptation review.
- Complete ATF and filter change according to manufacturer specifications.
John CC
close
- Join DateJun 2021
To reset the adaptive transmission on your 2018 Mercedes C220d, use the Key-On Pedal Method: ignition on (no start), press & hold accelerator to the floor for ~30 seconds, turn ignition off (still holding pedal), release pedal, wait 2 mins, then start and drive gently for 10-15 mins to let the TCM relearn your style.
Or, try this:
[Edit] I see I missunderstood you. When you said "Jolt after 4→5 upshift after proper ATF service" I took that to mean it didn't jolt until after the service. I see that is not what you meant. It's less likely the reset will help, but I'd still try it.
Or, try this:
