Hi guys, quick question, can i purchase a E350c, with the AMG package? or only 550
Yes because if you are in the USA, you can purchase the optional $1,950 Appearance Package for E350 Coupe. (Same package for E550 Coupe $1,250 because some of the components are standard already for E550 Coupe and/or the cost of replacement isn't as much).
No because you use the term AMG Package. Depends on where you are, the AMG Package can include slightly different components than what they are in the States. For example, the intake underneath the grill will look similar (or the same) as E550 Coupe if you order AMG Package in certain coutries. This is not the case for Appearance Package in the US though.
I actually would be buying in the US, and shipping it to my country...
Can i ask you a question, do you have any inside night pictures of your vehicle? i want to find out if the AMBIENT lighting is the same as the Sedan (which is really cool)...
thanx! !
As to ambient lighting, I looked at the car, played with cluster options, read the manual and visited MBUSA website and I do not believe the E Coupe has it as they do in E sedan. It however does have the LED lights under the door handles, give you sort of a little bit ambient lighting.
Ambient lighting is not available on the coupe. It has the lesser version of ambient lighting which is soft lighting in the door handles, front footwells, and a small light in the rearview mirror that shines down on the center console--but it is not like on the sedan where there is light coming out from underneath the wood strips and in the door panels.
