10' E550: Do side mirrors fold/bend down in reverse?
JT
I say after set up because until I did this, the mirrors did absolutely nothing when placing the car into reverse.
1. put car in run position but without putting your foot on the brake to start car, make sure safety brake is on.
2. switch mirror selector to right side mirror
3. place vehicle in reverse
4. adjust mirror to suit for reverse action usually downward angle
5. put vehicle into park
6. adjust mirror for normal driving position
7. turn off ignition
8. restart vehicle with engine running
9. place in reverse and mirror should look downwards, make sure the mirror selector is on right side, it should remember the last setting.
10. when putting mirror back into drive there is a delay in mirror returning to upwards or normal position, this is normal
hopefully I remembered everything correctly.
Thanks E350 Coupe for all of your help.
this procedure will only work if you have the memory seat package
