20 inch wheels and NOT lowered
https://mbworld.org/forums/e-class-c...eels-last.html
i can email you more.
they are genuine amg wheels from an SL550
Well, any time you're getting wheels with lips (especially when staggered with larger lips in the rear), these wheels normaly (very seldom there is an exception to this "rule") look an inch less than they realy are. That is because of lips, hence my comment.
And if you do go with 20s, then what your shop recommended is the way to go - larger than "sock" diameter tires (if they fit). I would assume 255/30-20 front & 285/25-20 rear, or 235/35-20 front 265/30-20 rear. Realy not sure if 245/35-20 will fit coupe's front, but if it does it would be ideal. Then you can safely run 275/30-20 rear. And NO lowering needed at all then.
https://mbworld.org/forums/e-class-c...se-wheels.html
