Shock Tower/Sensor?
Old Dec 22, 2011 | 09:27 PM
Raygt3's Avatar
2012 E550 Cab
Shock Tower/Sensor?
Anyone know what the sensors are that are mounted on the shock towers? One sensor on each tower.
Attached Thumbnails Shock Tower/Sensor?-hre-014.jpg
Old Dec 23, 2011 | 10:55 AM
Dueclaws's Avatar
'12 E550C, Sierra Denali
Ray-
I'm not sure, but are those to change the dynamic setting of the suspension (shocks)?
Old Dec 23, 2011 | 01:19 PM
Raygt3's Avatar
2012 E550 Cab
OK, a bit in the way of explination, am thinking of adding a strut tower brace and as you can see these guys are in the way of mounting the brace. That being the case they would have to be moved, not a real problem but....if these are actually accelerometers of some sort they would assume the sensors are OE mounted and in the same location for the calibration to be somewhat generic. If you were to move them or just let them hang off the wiring this would change the geometery and response of these guys and possibly create some unusual problems. So before I make any assumptions it would be a good thing to know what I was actually dealing with. Then again, if they are just some sort of simple switching device there might not be any problem moving them. Am a bit suprised there's not more detailed information available regarding these cars. So there you have the long and short of it.
Old Dec 23, 2011 | 02:34 PM
Dueclaws's Avatar
It's similar to my experience with installing a limited slip differential in the '12 E C. We might have to do some "pioneering".
Old Dec 23, 2011 | 03:03 PM
Raygt3's Avatar
2012 E550 Cab
That's the problem with early opt, when I bought my GT3 it was one of the first in the US and definately the first in my part of the state. Had to design and make alot of the suspension upgrade bits myself. Don't know about the E550 but it's the only one in my area. It's a bit of a struggle but rewarding at the same time.
Old Dec 23, 2011 | 03:52 PM
Dueclaws's Avatar
Agree
And we can share what we learn.
