Bluetooth audio streaming and 2010 models
Old Feb 26, 2015 | 10:26 AM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
I'm not totally sure, but I think you must have the Command system to stream Bluetooth audio. If not, Parrott has what you need.
Old Mar 30, 2015 | 03:22 PM
Gtrust's Avatar
E63
Bit of a thread resurrection
I have a 2010 e350cdi with command nav and Bluetooth phone etc. I've followed the instructions to activate Bluetooth music streaming which now appears in the audio list. However when I click on the connected phone (iPhone 6), it say connection unsuccessful and if you search for a device it can't find one.
Any help/suggestions would be gratefully received.
Old Mar 30, 2015 | 04:37 PM
Gtrust's Avatar
E63
figured it out, you need to externally authorise
Old Mar 31, 2015 | 04:26 PM
Gtrust's Avatar
E63
I thought I'd figured it out! When I turn the ignition off and back on again I have to do an external authorisation to get the BT streaming to work, it connects to the phone for telephone fine. Any suggestions?
Old Apr 1, 2015 | 09:25 AM
NCBob's Avatar
My Bluetooth streaming does not automatically turn on unless I first select a program such as Pandora or my music files on the phone. Then it streams. Upon restart of the car, usually the streaming is present. No need to select programs on the phone again if your phone is already set on any of the music sources.
Old Apr 4, 2015 | 11:49 PM
$100 GUY's Avatar
C207
How about cars without NAV?
Old Apr 6, 2015 | 01:06 PM
  #32
NCBob's Avatar
Your only option is the Aux cable located in the glove compartment or in the center console. Without Command, I think you have no Bluetooth streaming.
Old Apr 8, 2015 | 01:52 PM
  #33
$100 GUY's Avatar
C207
Even with the update?
So, does the Aux works with Android phones too?
Old Apr 8, 2015 | 02:50 PM
  #34
NCBob's Avatar
If your Android has a separate plug (not the one used for downloads or charge),
then you should be able to play music from your phone.
Dig out your owners manual to find out how to access your phone to play music via the aux cable. This is how I had to play music on a C300 that I no longer own. You need to select a category from the drop-down menu. Cannot remember which selection I used.
The Aux will not charge your phone.
Old Apr 10, 2015 | 12:16 AM
  #35
$100 GUY's Avatar
C207
Old Apr 11, 2015 | 04:40 PM
  #36
nanohead's Avatar
E550
I just picked up a 2012 cabriolet. I believe it should be standard, and just a part of the bluetooth connectivity mechanism. I just hit the disc button until the BT streaming option shows up
Old May 1, 2015 | 02:12 PM
  #37
Creative Audio's Avatar
Former Vendor of MBWorld
The older Comand units do not offer any kind of music streaming, unless you buy the module from benz themselves which can range up to $500. Does you car have the MMI port in either the center console or the glove box?
Old Jun 13, 2015 | 05:01 PM
  #38
S1CK TypeS's Avatar
So here is what I have learned so far. I went in to the engineering menu and turned on streaming. Im running an ipad mini for pandora and WAZE. What I have noticed is that it only decides to work intermittently. I have to reauthroize and even then it will sometime not connect. I have yet to get it to consistently connect every time. This is on a 2010 E63 with nav.
Old Jun 13, 2015 | 05:26 PM
  #39
Gtrust's Avatar
E63
That's the exact issue I have. Everything I turn off the car I have to re authorise the phone to play music. It must be a simple fix surely?
Old Jun 13, 2015 | 05:52 PM
  #40
S1CK TypeS's Avatar
it almost seems like MB thought about adding the feature and then said nahh **** these guys. Im hoping a software update will fix the issue.
Old May 25, 2017 | 10:28 AM
  #41
Saif_1987's Avatar
United Kingdom Car - Mercedes E Class E350 2 Door Coupe 2011 AMG Outline C207 diesel V6
Dear Mercedes Boys,
I have a question in regards the subject we are talking about .
I have an e class e350 2011 amg outline 2 door c207 model.
My Aux input is greyout and is un ticked in engineer mode, I cant enable it or select it the feature which is avaible to add or untick is " USE CAR BOOT " ?
The aux was talking find the MMI of mine is in the glovebox where the arm rest is i tried different media interface cable usb aux charging using the usb working fine but once I plug the aux in to the mobile no sound comes on at all .
It use to work find and it stop working all the suddent
My current engineer mode version is as follow;
SW build : 16.203
Date : 16.03.2011
Dev Name: HB_HU212MiD
Supplier type : 9013
Also how and where can I update the frameware of the interface ?? is there an software update for the interface screen ?
Please help i am getting very sad about this
