Bi-Xenon or not
Thanks for the help
If you have P1, you have the standard halogen headlights. I'm not much into mods., but I've read that others have found aftermarket xenons for conversion. If this is correct, you have to be careful about doing them in such a way as to avoid computer errors.
Perhaps others may know if you can upgrade to OEM P2 / bi-xenons post-acquisition, along with the adaptive high beam assist, etc. I'm kind of thinking that's not possible, but don't know for sure.
Also, if you have the P1 package, your DRL's (Daytime Running Lights) may not stay activated when you turn the headlights on and there may be no way to program them to do so. With the P2 package, the DRL's can be programmed to remain lit at reduced brightness when the headlights are on. Looks good that way.
Good luck with your new Benz.
If it's those above that you are referring to, that's great news. Just confuses the situation more, in that so many with the P1 package have reported they can't do that.
Maybe it's just the older style "hockey stick" shaped DRL's that can't be lit at the same time??
Anyway, I don't want to start another whole thread on the topic, so I'm glad yours work properly.
