Tire pressure warning.
So I go to page 253 and it says among other things:
Risk of accident and a lot of other dire consequences such as: Stop the vehicle, if necessary change a wheel, check the tire pressure, visit a qualified specialist workshop. So I check the tire pressure and it's just fine. I then go to see a qualified specialist workshop (my Mercedes dealer).
So what do they do? They also check the tire pressure and it's also just fine, even though the little yellow circle with the exclamation point is still on. No problem. They go on the steering wheel and using the on board computer, just turn the little yellow circle with the exclamation point off. So I ask the guy what if a real tire pressure problem crops up? He says don't worry, it'll come on again. (uh?)
I've been driving many, many years and many, many cars without the help of a tire pressure monitor, and all my tires always held up very well because I checked the pressure manually at least once every two months on average. Now I have this tire pressure indicator that will come on even though the tire pressure is perfect. Gime a break!
It was probably set previously with the pressure too high. Now that the pressure is lower (though actually the correct pressure) the monitor goes off. The dealer simply reset it to your current pressure.
The primary reason nitrogen filling of tires results in much less pressure increase is the nitrogen is dry, it has to be to not corrode the tanks it comes in among other reasons.
Since air is about 78% nitrogen, 20% oxygen and the rest trace gases if you are able to fill your tires with dry air, as that found in the air supply for spraying in quality body shops, you could get the same result for free.
When I was actively racing, some of my competitors used an the air drier unit from a heavy duty truck air brake system to fill their tires. The temperature shift relative to using dry nitrogen was neglibible.
