can't get climate control fan to come one...
Old Jan 20, 2013 | 11:13 PM
MSTRMOO's Avatar
2011 E350 Coupe
i'm in Toronto and its rather cold here today... i had to drive downtown and could not for the life of me get the climate control fan to turn on... i know the heat is turning on because when i get on the freeway, i can put my hand to the vent and feel a bit of heat coming out just due to the forced air coming through the vents at highway speed...
the fan is set to max, the heat is set to max, and the air distribution is set to the center vents a well as the front defroster... i've tried it in other air distribution settings as well..
am i doing something wrong?? i've looked in the manual and it seems like im setting everything properly...
Old Jan 21, 2013 | 01:03 AM
Maymin's Avatar
2006 e350 2008 & c350
I have a 06 E350. I have had this problem several times. Turning the car off and starting it again works for me, though this last time it did so after I started to drive off.
Old Jan 21, 2013 | 08:55 AM
AccelToronto's Avatar
Former Vendor of MBWorld
SpeedRiven SL600, ML320CDI
Thermostat might stuck open and does not let the engine to warm up sufficiently. Check the engine temperature...
Igor.
Old Jan 22, 2013 | 03:24 PM
MSTRMOO's Avatar
2011 E350 Coupe
It's the blower motor, and it's back ordered from Germany. Won't get my car back until next early next week.
Stuck with a c300
