passanger side rear window does not close properly
Please look in your owner's manual for instructions on doing a "Window Reset" and perform that. If that does not work, repeat the procedure.
If still no good, inspect around the windows for dirt or debris that may be causing the window to stick. If you find debris and you clear it, then perform the Window Reset again, twice if necessary.
If this doesn't work, then it's probably time for a technician to repair the window mechanism.
Please let us know how you make out. Good Luck.
