E350 Storage
Thanks!
If there is no electric available, three times per month letting it run for five minutes should be okay. You have to let it run long enough to replace the electric power used in starting it.
I would recommend running the car as near empty as possible before you store it or top off the tank and add fuel additives to remove water. I had my car in a non climate controlled storage facility, so I was concerned about condensation building in the tank. I always made sure I used the full tank during my stay... Never had a problem. The car today has just 20,000 miles and runs like a champ.
Add Stabil to a full gasoline tank.
Inflate tires to near maximum pressure.
Invest in a good car cover.
I just stored my E550 for the winter, 4 months, without any problems. Tires did not flat spot and the battery was just fine. Started up without a hitch.
I've done this without using a charger. Just disconnect the battery, and it will be fine for the few month intervals until you drive it again. Like I said, I've actually stored my car.
