transmission problem, brokedown
Im currently stranded in highway , my car can start however it wouldt enter the gear.. Drive or reverse .. I tried paddleshift not working either.. Anyone knows what the problem? Is it because of trans mission slip? What can i do? How to check the transmission fluid? Its sunday all the workshops r closed.. Thanks
When you press the brakes, do the brake lights illuminate? Perhaps the brake sensing switch is broken and is not allowing the car to shift into gear.
I'm leaning to wards something electronic, but not really sure. Sorry man, I'll keep thinking about it. Good luck!
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
How old is your car? Should be covered under the 4 yr 50,000 mile warranty if you're within those parameters. Shame, I believe many other manufacturers usually warranty the power train longer than the basic warranty. It looks like MB does not.
panel services > authorized mercedes service center
