offset help
Old Nov 6, 2013 | 06:02 AM
16500257's Avatar
e200 coupe
offset help
hi guys
my car is e200 coupe.
i plan to order work vs-xx.can i run 255/35/18 18x9 et30 front and rear without rubbing.
please give me some advice thanks.
Old Nov 6, 2013 | 10:50 AM
Dueclaws's Avatar
'12 E550C, Sierra Denali
Originally Posted by 16500257
hi guys
Try searching this forum: there are many threads about offsets, etc.
I believe: et30 is too much offset.
Old Nov 6, 2013 | 02:40 PM
2010_E550's Avatar
2010 E550 Coupe
just so you know, there are conservative people on this website, most will tell you it wont be possible. it all depends on how you set it up. it would be best to install coilovers first, then you can dial in the ride height to fit the wheels.
18x9 will look very small. in order to make those fit you will need to run a 225/40/18 and it will look weird on the c207 chassis.
if you are going to order work wheels, then think more about the size and offset. below is a good starting point. math is your friend.
19x8.5 et 40
19x10 et 40
Old Nov 9, 2013 | 01:53 PM
16500257's Avatar
e200 coupe
ok,i will try. thank u
Old Dec 11, 2014 | 01:51 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
I was searching for the stock winter wheel size for 2012 couple/cab manual today to see if my 8 x17 et45 winter wheels from my 2011 E350 wagon will fit the 2012 Cabriolet.
I would appreciate it if someone could take a peak at their manual and tell me what the recommended winter wheel size is. A photo of the relevant page would be a bonus.
Thanks.
