W207 wind deflector fuse location or where in Xentry ??
Old May 5, 2014 | 08:57 PM
terrymargate's Avatar
merdeces s320
I have 2011 W207 E350 convertible and the wind deflector flap just stopped working, nothing lights when you press the button next to roof opener.
I cannot find the fuse for this, any ideas?
also I cannot find its location in Xentry to diagnose and troubleshoot
I've been through all menus but must have overlooked it, I'm guessing its in a submenu.
All advice appreciated
Old May 6, 2014 | 10:18 AM
theraven333's Avatar
Mercedes E350 CD Iridium silver convertible 2010
Are you talking about the "air deflector" that rises from the top of the windscreen???
When you press the button do your rear headrests rise?
If yes then the controller and power are working, if the wind deflector on the windscreen is not rising then you have another issue.......You could try doing a command reset, this may or may not help.........
If it is the deflector not rising, then unless you have access to the Star Diagnostics, then it is a trip to your Mercedes Dealer........
My car is currently at the dealer for the deflector not rising...............I hope your car is under warranty as if it isn't this then you will not believe how expensive the assembly is! and when it is faulty they replace the whole assembly..... no small parts>>>>>
I also have the Mercedes WIS on my laptop and it is incredibly hard to find any diagnostic data on this part, I can only find removal and installation of the whole assembly!!!!
Old May 6, 2014 | 12:28 PM
hillcreative's Avatar
2011 E350 Cabriolet
A search on this issue will reveal that the most recent convertible top ECU upgrade can cause the air deflector to fail.
