Tire sizing question...
I was looking to get a set of winter tires (blizzaks LM60) with sizes of 225/40/18 and 255/40/18 for front and rear, respectively, but was wondering if that might be too much of a size difference from OEM and/or too staggered that it would hinder drive ability. These would be going on OEM rims on an a 2011 E550.
Thanks in advance!
edit:
specifically, with a larger difference for front vs rear, I was wondering if there might be issues (drive ability, suspension, etc.)
Where are you located? If your winters are soft then stagger with stock setup size. If not, and you actually "need" good snow traction, I recommend the narrow profile (225 or 235).
I was worried about the front vs rear difference. There's about a 4% difference in diameter b/w the 225 and the 255 (the rear being larger). The stock tires have a less than 2% difference (with the front actually larger in diameter). From what I gather, having larger rear tires will promote under-steer, but I was wondering if there would actually be any damage to any sensors or the any part of the car because of this discrepancy.
