Interior Trim Removal help needed
Old Jan 16, 2015 | 05:33 PM
patrickkc's Avatar
E63S || C63 || E550 Coupe || Cayenne ||
I'm trying to remove my interior trim for the CF treatment, but I have no idea how to remove the dash trim.
I assume the door trim, ash tray trim and the shifter trim has the same removal steps as the W204. But the trim on the dash, I have no idea how to remove it. I looked up some W212 trim removals, but their wood trim seems to be attached to the vents which pull out.
any help would be much appreciated!
Old Jan 20, 2015 | 07:30 PM
patrickkc's Avatar
Nobody has taken off their trim before?
Old Jan 23, 2015 | 02:47 PM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
Try this:
https://mbworld.org/forums/w212-amg/...od-panels.html
Old Jan 24, 2015 | 10:58 PM
patrickkc's Avatar
I actually looked at that thread before. The middle wood trim is pretty different from the W212 so not sure how this will play out. I'll probably play around with it when the weather gets a bit milder..
Old Jan 25, 2015 | 12:03 PM
SnakeDoctor's Avatar
2014 E550 Coupe and 2010 E350 Sedan
Heh, this was one of the main reasons I didn't do this. I had no idea how to take the pieces out. I think I read somewhere that the door pieces will involve removing the door panel. You should just go to the MB dealer and ask a tech.
