Valentine One Radar wiring
Old May 28, 2015 | 03:09 PM
cmlf1's Avatar
e550 coupe
Has anyone wired a radar detector in a C207? I have a V1 and want to wire it into the car. The BMW I replaced had plenty of places for auxiliary electronics, do these cars as well?
Thanks!
Carl
2010 E550
Old May 28, 2015 | 06:03 PM
Fretboard's Avatar
2012 E350 Coupe
I wired an old Passport detector in my 1995 C220, but was reluctant to do so with a V1 in my 2012 E350 coupe. Took it to a local car stereo place and they did a great job hardwiring to a circuit that was hot when the ignition was on. I keep the V1 on the passenger visor so I suspect they used a circuit accessible through the mirror mount, such as the pano top.
Old May 29, 2015 | 10:48 AM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
Thanks!
Carl
2010 E550
Go to the Valentine web site and order the Savvy. It plugs into the OBD port under the dash. Running the wire to the V1 takes about 5 minutes.
There is also an adjustment that lets you set the car speed at which the V1 activates. Any signals under that speed with not set the V1 off, eliminating false alarms.
After turning the engine off, the V1 shuts off when the interior lights go out.
I've had mine for three years with no issues.
Old Jun 1, 2015 | 07:19 AM
Pennetta's Avatar
19 E53 AMG Cab, 21 Land Rover Defender 110S, 20 LR Discovery HSE, 23 Ford Bronco 2dr 7spd Manual
For top of windshield under visor mounting: There is a 12v socket in the glove box which operates with the ignition switch. Plug into glove box--->up passenger side A-pillar-->across top of windshield trim--> out by rear view mirror into detector.
Old Jun 1, 2015 | 10:59 AM
cmlf1's Avatar
e550 coupe
Going to look at the Savvy. Thanks everyone!
