does anyone know the stock turbo boost in lbs on a new e400 - V6 twin turbo?
Old Jan 6, 2016 | 10:59 AM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
Question does anyone know the stock turbo boost in lbs on a new e400 - V6 twin turbo?
or psi - thanks in advance! i can't seem to find this info online.
Old Jan 6, 2016 | 11:12 AM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Sorry but I don't remember the specifics (or the source) but I remember before I bought the E400 that some article was saying that the 3.0l TT V6 runs an unusually high boost pressure. There is also a 3.5l TT V6 rated at the same horsepower and torque that is said to run a lower boost pressure and is used for different applications.
The 3.0l engine is engine model M276 DELA 30. The 3.5l version is model M276 DELA 35.
I'm having a lot of fun with the "little" TT V6, even after driving a V8 Lexus for almost 15 years. This thing is just a blast - with all that torque at such a low engine speed.
One question - If you pull away from a stop in 'E' mode (2nd gear), and press down about 1/3 on the throttle, is your acceleration even, or do you sense a bit of a "surge" where the car jumps ahead, hesitates a split second, then takes off hard again? I sometimes have this, but I am not sure if I want the dealer to mess with it, as the car runs so well that I'm afraid to let them at it for fear that they will do something that softens the throttle response to get past the "lag."
Old Jan 6, 2016 | 11:18 AM
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
Good discussion here (but not sure if actual/true psi rating is given):
https://mbworld.org/forums/e-class-w...6-biturbo.html
Old Mar 12, 2016 | 12:38 PM
E400-CH's Avatar
E400
Hey Steve:
2015 E400 - 4,500 miles. Yes. Same exact thing with mine. Moderate acceleration in Economy does result in an odd surge in second gear. Switching to S mode with the first gear start doesn't have the same result. I too have thought about raising the question with the dealer, but am probably not going to bring it up.
Questions for you and other E400 owners -
- Has anyone noticed a very loud "gurgle" out of the passenger exhaust upon starting? After 60 seconds it is then pretty quiet.
- Has anyone noticed unusually hard transmission down-shifts during above average braking? Example: Coming off of an expressway and applying harder braking, I can feel the transmission downshift hard through each gear until stop.
Thanks!
-chuck.
One question - If you pull away from a stop in 'E' mode (2nd gear), and press down about 1/3 on the throttle, is your acceleration even, or do you sense a bit of a "surge" where the car jumps ahead, hesitates a split second, then takes off hard again? I sometimes have this, but I am not sure if I want the dealer to mess with it, as the car runs so well that I'm afraid to let them at it for fear that they will do something that softens the throttle response to get past the "lag."[/QUOTE]
